Powder coated CDS steel tube chassis.
Double side impact protection bars in addition to main chassis tubes.
Double roll over hoops - longitudinally braced
Front crash structure
Rear crash bars
Fire extinguisher and external ignition cut-off (optional extra)
Cockpit
6 point 75mm FIA approved harnesses
Adjustable pedals, steering column and seat
Right or left hand drive - re-configurable by owners
Instrumentation - programmable combined analogue tacho/digital speedometer; plus digital oil pressure and water temperature.
Warm air control - ducted directly from radiator.
Engine and Transmission
VW Audi Group 1.8 litre turbo
5 valves per cylinder
210 bhp, 225 lb ft torque
KKK turbocharger with intercooler
Electronic throttle control
Stainless steel exhaust system
VW Audi Group 5 speed manual transaxle gearbox
Suspension
Ohlins springs and dampers with adjustable ride height, compression and rebound
Pushrod activation of inboard mounted springs/damper units
Adjustable front anti-roll bar
Adjustable camber, ride height, compression and rebound damping
Unequal length double wishbones front and rear
Cast aluminium lightweight uprights
Brakes
AP Racing calipers - four pot front - two pot rear
260mm ventilated discs
Twin master cylinders with adjustable front/rear balance
Wheels & Tyres
Rimstock Team Dynamics Pro-Race 1 lightweight rims - 15in by 7in
Toyo Proxes T1-S 195/50 front, 225/50 rear
